Form finding double curved shell with kangaroo
Hey there,
I want to create a double curved shell (e.g. like the Trabeculae Pavilion) with kangaroo.
I found a way by generating the outer arches with kangaroo and rotated those outwards. Then I located the highest points there and generated a hanging line again with kangaroo inbetween.
I then finally created the shell by using Sweep2, adding two rails (between the bottom points of the arches) as sections.
Now I want to find a better way to model the same shape by creating a mesh surface.
I tried to add a definition (blue box) to show what I’m trying to do but achiving said shape.
I hope the grasshopper file is clear enough.
Thank you!
Gesa
Trabeculae_Pavilion.gh (61.3 KB)
Trabeculae_Pavilion Edited v0.gh (68.8 KB)
Trabeculae_Pavilion Edited v1.gh (76.1 KB)
V1
Thank you!
What changes do I need to make if I want to make it asymmetrical? Like in the scribble here:
Kind regards,
Gesa
You can generate the side using curve or catenary … then make network surface, then quadremesh this then Kangaroo from Quan Li.
Trabeculae_Pavilion LD.gh (22.6 KB)
I assume you will need the aligned grid for morphing, and have more contol over the borders,so just because of fun: The surface from the original post seems like it could be a cut piece, of an Enneper Surface, which is a minimal surface, mathematically described by Alfred Enneper in 1864.
You can model it with the knwon equation like this:
enneper.gh (20.7 KB)
