I noticed that sometimes named selections are missing after reopening the project. Is it known bug or they should be temporary?
Hello - selection sets should be saved in the file. If you have a repeatable way to make that fail, please shout.
I think I found the bug. I have 3 named selections under keyboard shortcuts.
I noticed that they do not activate named selections after opening the project. But when I click “named selection” tab they start to respond. But If I open the project, DO NOT click on “named selections” tab and save the project again, they are deleted permanently.
Hi -
I can reproduce this part and will write it up.
RH-63405: NamedSelection: Command-line version needs dialog activation
I’m not seeing this part. When I save the file and then reopen it, the named selections are still in the file. Which version of Rhino 7 are you running?
I saved the file without clicking on “named selections” before and selections were saved :).
But this situation happened few times so I am sure that there is some problem. I will post more if I find something that can be recreated.
I have the same problem. Trying to track it and find a way to repeat it.
Looks like sometimes they are saved and sometimes not. I just opened the project and they are missing.
Hi, is this matter resolved? I am also having named selections not saved.
Same problem here. Close file without even saving and when I open again, POOF! The named selections are gone.
I’m fabricating at the moment so only using the file for visual reference and not modifying anything, hence not saving the file when I close. This has now happened on three files and I cannot for the life of me work out what is going on. It’s exceedingly annoying.
Hope this can get fixed.
Steve
I am having the same problem.
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Lab-Lizenz, build 2022-05-04
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 4-20-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.59
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-20-2022
Driver Version: 30.0.15.1259
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
can you provide steps to reproduce this behavior?
@wim was able to create a reproducible example and we have filed a ticket here.
RH-68727 is fixed in Rhino 7 Service Release 20
I still get this issue. Selecions disappear upon opening the file. Please advise.
Hi Sven -
Please run the Rhino SystemInfo
command and copy-paste the result here.
Rhino 7 SR24 2022-11-4 (Rhino 7, 7.24.22308.15001, Git hash:master @ cb2ad12922ceb989b185972675bb705a00abb97d)
License type: Commercial, build 2022-11-04
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce GTX 1660 SUPER (NVidia) Memory: 6GB, Driver date: 3-17-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.15
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 3-17-2022
Driver Version: 30.0.15.1215
Total Video Memory: 6 GB
C:\Users\Stolno Racunalo\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22290.1357
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.24.22308.15001
Hi Sven -
I’m not able to reproduce that here in a quick test.
Does that still happen when you disable the 3rd party plug-ins and restart Rhino?
Yes it does unfortunately…
Hi Sven -
In that case, please provide as much information as possible for step-by-step instructions on how to reproduce that issue.
