I’m trying to upload a revised version of my plugin AImanTools. The icons in the project where referencing to a specific folder and that made the plugin not work on other PCs. I had to modify and rebuild.
But whenever I try to reupload the new .zip file it gives an error:
The uploaded file is suspected to contain viruses or potentially malicious software, or is password protected. Please clean your files with an antivirus before uploading, or upload an unprotected password file.
I’ve checked the file on more than one antivirus and it is clean. Also, it has no passwords.
Currently, I had to unpublish the plugin.
Thanks for reaching out, Abdulrahman! Jordi on the F4R team mentioned that he’s already in contact with you about this issue. Once the issue is resolved we can update this thread in case others run into the same problem.
Hello Will.
Thanks for you reply.
We resolved it by “me creating a draft with the updated version” and then Jordi published it from his side. However, I’m afraid the same problem happens when uploading the next version and having to go through the same solution which I don’t think is a sustainable one.
I found a similar issue in the forum from 2022 and someone from McNeel mentioned something about McNeel’s antivirus system requiring update.
