Hi all, it’s me again,
Why can’t use along surface command on this surface and this line? I think it’s a simple command, I’m doing something wrong.
Thank you.
Thank you.
Hello - see Help on FlowAlongSrf
to see how that command works. I think what you want here is Project
from the Front viewport.
I tried, I read step 1, step 2 and the options and nothing. Project is not working on these particular surface and curve. I changed the curve size to match the surface circunference and nothing.
Thank you.
Maybe I am wrong but based on your screenshot it looks like you don’t have a Base surface. FlowAlongSrf requires a Base Surface (unless you are using the plane option which prompts you to draw a plane) and a Target Surface. See the little video on the help page here.
Thank you very much.
Now I understand, you helped a lot!
