I’m in Rhino 6 and I noticed often that commands cannot run while I’m in a floating viewport. No response to my typing in the command line. As if the main rhino window and my floating viewport were two separate application windows.
any ideas?
any ideas?
Hi Will - so, if your cursor in on a floater (same or different monitor?) command line input fails, correct? Or do you place the cursor in the command line explicitly? (both should work as far as I can see here).
it’s the first scenario.
I have two monitors. float viewport is on 2nd screen while main on 1st. I’m in float viewport actively and as I type nothing happens in the command line in main.
This only happens once in a while.
Hello - if you can pin down a condition or sequence of actions that makes this happen, that would of course be useful. I don’t recall having heard of this until now…
