Floating Command Window Disappeared
I’ve been floating my command window to gain some extra screen real estate. The stupid xNurbs licensing manager started throwing errors on Rhino’s startup. I disabled it, restarted Rhino, and now the command window is gone.
It shows up momentarily at startup. I can see it blocking the plugin. Then it disappears. Any idea how I can restore it?
I used Tool → Import Options to reload my settings, and it showed back up, but in a docked position.
I have the same issue, but didn’t save an options file up to now… does anyone have another idea? (i’m having this issue only on Windows, never happened on Macos).
R8.13.24317.13001
Hi Christian -
Use WindowLayout to restore the factory-default layout. You can save your current layout as a custom layout first.
