Hello everyone, I hope you can help me out. As you can see in the gif, the size of the object snap highlight is exagerated and I can’t find the menu to fix that size. Thank you.
Hi Lucius - can you please run the SystemInfo command in Rhino and copy/paste the results here?
Of course, here it is what it displays, thank you.
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Evaluation, build 2024-01-09
License details: Stand-Alone
Expires on: 2024-04-12
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 63Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P620 (NVidia) Memory: 2GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: (null)
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 1-22-2020 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: On
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: n/a
Total Video Memory: 2 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
Hi Lucius -
Why are you running Rhino in Safe Mode?
Hello, I didn´t notice that, thanks. However, as I run the normal mode the issue stills there.
.NET 7.0.0
Primary display and OpenGL: NVIDIA Quadro P620 (NVidia) Memory: 2GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Z-Buffer depth: 24 bits
C:\Users\ARQ\Documents\programas\elefront\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15001
Hello, whenever I select an object by snap the selection does this and it messes up the precision I need. Is there a way to change the thickness of the highlight?
Hi Lucius - that does look very wrong. Does that happen in any display mode?
Actually it doesn’t happen in another display mode.
Since Wireframe is the most I use, I didn’t come out to explore the others.
Thank you so much Pascal.
Hi Lucius - what does this page in Options > View > Display modes > Wirframe > Objects >Curves look like?
If you reset that mode to defaults, does the problem go away?
Yes, I did reset that when you mentioned before and the problem is solved.
Thank you so much.
