FitCrv appears to be constrained so that the resulting curve is tangent to the target curve at either end.
Is it possible to relax this constraint?
What does the AngleTolerance parameter in FitCrv do? It is not mentioned in the documentation I’ve found. Major changes to the value do not change the results.
I’m using: Version 5 SR8 64-bit (5.8.40224.15545, 2/24/2014)
