Fit Ellipse Through Points
I need to make a ellipse shape through some points. Is there anything in rhino that can do that similar to Circle: fit points.
Ellipse From Points.3dm (43.3 KB)
Hi Tommy - none that I know of, no.
You could look into these old topics for ‘workarounds’:
Hi there,
This is a script for Rhino8 using Numpy, we could also use the MathNet.Numerics if we wanted it to be compatible with Rhino7.
To use it with Rhino7 you can make a py script that gets the data, stores it in a json file, and then runs this file that will read the json and perform the calculation. Hope It’s clear.
Script.py (the one to run on rhino)
import json
point_ids = rs.GetObjects("Select points", rs.filter.point)
if not point_ids:
    print("No points were selected.")
else:
    # Convert point IDs to XYZ coordinates
    points = [rs.PointCoordinates(id) for id in point_ids]
    points_data = [{'X': p[0], 'Y': p[1], 'Z': p[2]} for p in points]
    file_path = rs.SaveFileName("Save JSON file as", "JSON Files (*.json)|*.json||")
    if file_path:
        with open(file_path, 'w') as file:
            json.dump(points_data, file, indent=4)
        ironpython_path = "path_to_your_ironpython_exe"
        calculator_file = "path_to_calculator.py"  # Specify the path to your calculator.py file
        subprocess.run([ironpython_path, calculator_file])
Calculator.py
import json
import numpy as np
from numpy.linalg import eig, inv
with open(Points.json', 'r') as file:
    points_data = json.load(file)
x = [p['X'] for p in points_data]
y = [p['Y'] for p in points_data]
def fit_ellipse(x, y):
    x, y = np.array(x), np.array(y)
    D = np.vstack([x**2, x*y, y**2, x, y, np.ones_like(x)]).T
    S = np.dot(D.T, D)
    C = np.zeros([6, 6])
    C[0, 2] = C[2, 0] = 2; C[1, 1] = -1
    E, V = eig(np.dot(inv(S), C))
    n = np.argmax(E)
    a = V[:, n]
    return a
ellipse_params = fit_ellipse(x, y)
# conic equation Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0
# for ellipse, we need B^2 - 4AC < 0 (for a real ellipse)
A, B, C, D, E, F = ellipse_params
is_ellipse = B**2 - 4*A*C < 0
is_ellipse, ellipse_params.tolist()
This works with a really great degree of precision I am veru satified with the result.
It was an intresting problem, hope this helps
If you need help setting this up just hit me up.
@Tommy804
Since this wish comes up every now and then, I’ve logged it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-78096
– Dale
Thank you to helping… sorry for the year long reply. I was hoping you’d be able to help me implement it in rhino7. Im not familiar with coding so i need a little help.
RH-78096 is fixed in WIP
