hey folks,
I’m working on a GH fabrication script for angle connectors between some sheets with different angles. The profile ending, which touches the sheet is the same on each connector.
Later I wanna nest every angle-profile for fabrication.
Now I generated in GH the angle section curves but I can’t find the correct perpendicular / orthogonal planes for constructing the joint profile. May anybody of you guys can give me a hint? thanks a lot
some thoughts:
While intersecting the circle profile with the surfaces, I’m getting a bunch of smaller section curves, which aren’t relevant – but may these “duplicates” generating the non-perpendicular planes? Also I can’t join the profile curves for getting a correct boundary.
angle joint connectors.gh (18.7 KB)
angle joint connectors.3dm (3.9 MB)
