Hello
I am working on a definition which creates points at the intersections of a grid of Rhino Curves (each of which is named in Rhino in Properties panel; i.e. ObjectName). The X gridlines are named (A,B,C…) while the Y gridlines are named (1,2,3…). I want the baked intersection points to be named (A1, A2…B1,B2…C1,C2…).
I have successfully produced a list of intersection point names (A1, A2…B1,B2…C1,C2…). However, I am interested to know if there is a more elegant way of achieving this.
The second question is about how to bake these names into the baked points. I am attempting to use Elefront Attributes, and I am getting the following error: “1. The Geometry and Attributes tree must match exactly.” I understand that this has to do with the structure of my lists and trees (regarding which I am still a novice). A little help on this would go a long way.
What is the best way to reach my goal of points at each grid intersection, named for the grid intersect?
By the way, I have attempted to follow this, the only relevant post I found, to no effect (it doesn’t make sense to me).
https://discourse.mcneel.com/t/naming-intersection-points-by-attributes/101150
Thank you
Brian
