See how those highlighted points are close to each other? I’m trying to find a way with Python scripting to give me a warning message if 2 points are found to be close to each other. I would like to be able to define the acceptable distance and any points found close to each other (closer than the distance I defined) will be flagged.
Any suggestions? I’ll keep plugging away at this but I’m definitely open to suggestions.
HI Dan,
Maybe something like this? - it’s a bit of a neanderthal hack, but you get the idea…
def FindPtsTooClose():
atol=rs.UnitAbsoluteTolerance()
min_dist=rs.GetReal("Minimum distance to select points?",atol,atol)
if min_dist is None: return
pt_objs=rs.ObjectsByType(1,state=1)
if not pt_objs: return
found=set()
pts=[rs.coerce3dpoint(pt_obj) for pt_obj in pt_objs]
for i in range(len(pt_objs)):
for j in range(i+1,len(pt_objs)):
if pts[i].DistanceTo(pts[j])<=min_dist:
found.add(pt_objs[i])
found.add(pt_objs[j])
if found: rs.SelectObjects(found)
FindPtsTooClose()
