Using Rhino.Common, I can prompt the user to select a sub-surface of a polysurface (which I’m adding to the document for further manipulation). How can I obtain a reference to the polysurface that contains this subsurface?
Here’s my code for sub-surface selection.
import Rhino
import System.Guid
import scriptcontext
def GetSubSurface(prompt="select subsurface"):
# get a surface of an object
go=Rhino.Input.Custom.GetObject()
go.GeometryFilter=Rhino.DocObjects.ObjectType.Surface
go.SetCommandPrompt(prompt)
go.Get()
print go
objref = go.Object(0)
go.Dispose()
brep = objref.Face().DuplicateFace(True)
guid = scriptcontext.doc.Objects.AddBrep(brep)
if (guid != System.Guid.Empty):
rc = Rhino.Commands.Result.Success
scriptcontext.doc.Views.Redraw()
return guid
