Filter Circle with Diameter/Radius smaller than
I am new to grasshopper and I start a new topic because I could not find what I am looking for (here and via Google) - and I can not get the solution by myself (yet).
I used the imageprocessor to create a “Picture” just by using circles with different diameters. Now, for further processing, I need to filter out and delete circles with a diameter smaller than (for example) 0.4mm. Or in other words: I just want to display (and use) circles with a diameter larger than…
At the Moment my Output are CNR circles. Well, now I need to get the radius of each, use smaller than, etc. - but all I manage to get are liste with true and false.
I am not familiar with Scripting etc.
Thanks for help in advance.
Regards!
hi,
it sounds like an easy problem but pls upload a file and image for people to understand better.
you’ll find guidelines here:
As Aris said, best to include your model so people can help you better, but here is a simple example showing one method to filter curves based on radius/diameter.
CircleFilter.gh (10.5 KB)
ImageProcessing_MPL.gh (3.7 MB)
Thanks.
As you can see, I have thousand of circles as a result and I need to filter / delete circles smaller than e.g. Diameter 0.4mm.
Like this?
ImageProcessing_MPL_Rev2.gh (3.7 MB)
Check this as well.
ImageProcessing_MPL_re.gh (699.3 KB)
You made my day :wink: Thank you!
Thank you!.. different, also seems to work. But you deleted that Divison which allows me to scale the circles in proportion to the grid.
