I have a pair of edges I’m trying to fillet. The FilletEdge command in rhino does it no problem. But the rhinocommon FilletEdge does not work. It can only fillet one edge at a time, which, combined, doesn’t result in a clean fillet across both edges. Any thoughts on how I can fillet both edges with Rhinocommon?
Yes, I’m using Brep.CreateFilletEdges. Below is my code, where LastFront is the brep being worked on.
Thank you,
Sam
Dim EdgeIndicesToFilletList As New List(Of Integer)
For i = 0 To LastFront.Edges.Count - 1
If LastFront.Edges(i).GetBoundingBox(True).Max.X < ChopBoxPlaneOrigin.X + 0.1 Then
EdgeIndicesToFilletList.Add(i)
End If
Next
Dim TopEdgeIndex, BottomEdgeIndex As Integer
If LastFront.Edges(EdgeIndicesToFilletList(0)).GetBoundingBox(True).Max.Z > LastFront.Edges(EdgeIndicesToFilletList(1)).GetBoundingBox(True).Max.Z Then
TopEdgeIndex = EdgeIndicesToFilletList(0)
BottomEdgeIndex = EdgeIndicesToFilletList(1)
Else
TopEdgeIndex = EdgeIndicesToFilletList(1)
BottomEdgeIndex = EdgeIndicesToFilletList(0)
End If
Dim FilletedLastFront = Brep.CreateFilletEdges(LastFront, {TopEdgeIndex, BottomEdgeIndex}, {3}, {3}, BlendType.Fillet, RailType.RollingBall, 0.001)(0)
