I have a brep with many brepfaces,and want fillet all edges with the same fillet radius using c++ codes.
test.rar(1.9 MB) has the test 3dm file and the codes I write,but it can’t fillet success.
another problem:
if I using filletedge command fillet the test 3dm,will also not success.but if I explode the brep,and them join them
again,this time using filletedge command will success.
How was the Brep in Test.3dm built? If you built it with Rhino, did you change the model’s units or scale the geometry?
Also, instead of doing this:
CRhinoFilletEdge* edge = new CRhinoFilletEdge;
if( edge->FilletEdges(...) )
just do this:
if( CRhinoFilletEdge::FilletEdges(...) )
dale:
I built it with rhino.and does’t change the model’s units or scale the geometry.
my problem I think is how to get the edges which can be filletted.
the function I write to get the edges have problem,because it can’t get any edges.
Can you provide me step-by-step directions on how you created the surface?
next is the main codes created the surface.
on_Brep* CreateZS(ON_SimpleArray<ON_Curve*> &topcs,ON_SimpleArray<ON_Curve*>&botcs,double angle)
ON_SimpleArray<ON_Brep*>breps;
//放样生成侧面
for(int i=0;i<botcs.Count();i++)
ON_SimpleArray<ON_Curve*>curves;
curves.Append(botcs[i]);
curves.Append(topcs[i]);
ON_SimpleArray<ON_Brep*> tempbreps ;
g_nurbsAlg.LoftToBrep(curves,false,1,0,tempbreps);
for(int j=0;j<tempbreps.Count();j++)
breps.Append(tempbreps[j]);
//加盖生成顶面;
ON_SimpleArray<const ON_Curve*>plane_crv;
for(int i=0;i<topcs.Count();i++)
plane_crv.Append(topcs[i]);
ON_SimpleArray<ON_Brep*>topBrep;
RhinoPlanarSrf(plane_crv,topBrep);
for(int i=0;i<topBrep.Count();i++)
breps.Append(topBrep[i]);
//合成整体;
ON_Brep* brep=RhinoJoinBreps(breps,0);
if (brep)
ON_Brep * outbrep=g_nurbsAlg.BrepFillet(brep,m_angleRadius,0.2);
if(outbrep)
delete brep;
brep=outbrep;
for(int i=0;i<breps.Count();i++)
delete breps[i];
return brep;
can anyone give a example how to write this function
on_Brep* FilletBrep(on_Brep* in_brep,double filletRadius);
help me to see my problem please
Instead of this:
ON_Brep* brep = RhinoJoinBreps( breps,0 );
Try this:
ON_Brep* brep = RhinoJoinBreps( breps, 2.1 * doc->AbsoluteTolerance() );
Does this help?
dale:
this still can"t work.
can you give me a full example
