Fillet in ghpythonlib
I’m trying to call Fillet 2 with out parameter, but I only see Fillet 1. what should I do?
Thank you.
Hi @Shank ,
Are you trying to call the actual “Node To Code” aka the GH component?
Otherwise you can just do this:
Graph Space:
Model Space:
__author__ = "Michael Vollrath"
__version__ = "2023.08.20"
#Made With <3 In Dallas, TX
ghenv.Component.Message = None
O = rs.AddFilletCurve(C1,C2,R)
yes, i’m trying to call Node to code.
but I want fillet curve by python look like picture below. Any ideas ?
Here you go, this should be a match for the functionality of the component:
Graph Space:
Model Space:
ghenv.Component.Name = "Fillet (Python)"
ghenv.Component.NickName = "Fp"
ghenv.Component.Description = "Mimicks the Fillet component"
ghenv.Component.Params.Input[0].Name ="Curve"
ghenv.Component.Params.Input[0].NickName ="C"
ghenv.Component.Params.Input[0].Description ="Curve To Fillet"
ghenv.Component.Params.Input[1].Name ="Radius"
ghenv.Component.Params.Input[1].NickName ="R"
ghenv.Component.Params.Input[1].Description ="Fillet Radius"
ghenv.Component.Params.Output[0].Name ="Curve"
ghenv.Component.Params.Output[0].NickName ="C"
ghenv.Component.Params.Output[0].Description ="Curve With Filleted Corners"
import Rhino
#Get Document Tolerance Settings
tol = Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance
aTol = Rhino.RhinoDoc.ActiveDoc.ModelAngleToleranceRadians
#Fillet Curve
C = rs.coercecurve(C).CreateFilletCornersCurve(C, R, tol, aTol)
20230820_Python_Fillet_Curve_Response_01b.gh (7.1 KB)
Thank you too much.
You’re welcome! Happy filleting
