Hi, i would like to fill this hole, is there any command that i should try to solve it
Hello - it looks like Untrim is what you need here but also your object looks to be split up into multiple faces that might be unnecessary - can you post a file with that object?
i tried with untrim but it didnt work. When i was workin with a surface without thickness, the command untrim used to be efficient, but now, as i transformed the red surface so it get thickness, the untrim command doesnt work
I dont know why but i cant upload the file:(
Hm - is the file huge?
export.3dm (533.7 KB)
