File Path Node inside Definition
Hi, is it possible to set/change the path inside the Visualarq Definition?
Inside the Definition, the path node is not visible
Hi @bjornsmolarek, file paths are not identified as parameters for VisualARQ Grasshopper styles. We may make this work in future versions though.
Too bad but thanks for the answer
@bjornsmolarek can’t you just use a textual input as a parameter for the folder, instead of a “file path” Grasshopper input?
I tested your tip and it works. Now I can adjust the path in the Visualarq object.
