VisualARQ 2 - Version 2.0.18 released
VisualARQ 2.0.18 is now available for download.
This is a minor release that solves most of the issues reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
New features:
Changes:
  • Grasshopper Components:
    • Now it is possible to assign multiple custom parameters or properties at once.
Fixed bugs:
    • Fixed a bug when assigning custom parameters to Rhino objects.
    • Fixed a bug when creating a spiral stair in documents in imperial units.
    • Spiral stairs can be now created from NURBS arcs.
  • IFC:
    • Fixed a bug that didn’t solve properly a wall intersection from an imported IFC file.
  • Walls area was not correctly calculated in documents in millimeters.
  • Fixed a bug that didn’t let select a tag on a column object.
  • It was not possible to assign certain colors as line print color.
  • Some hatch objects were not generated in plan views.
  • Layers from inserted models were duplicated if there were existing layers with the same name.
  • Fixed a crash after running the Group command
Known bugs and limitations:
  • Expressions in Grasshopper Params are ignored when displaying the value on VisualARQ properties panel.
Enjoy!
Enric
Hi all! I have a trial version that will expire in a month but I saw that you fixed some bugs about drawing instances and blocks with this or the last minor release. Is it possible for me to obtain this version for the rest of the trial?
Thanks for your help!
Hi @AleM_29,
Yes, you can download the latest update from http://www.visualarq.com/download/update using you trial license key.
Regards,
Enric
Thanks a lot for your quick answer!
is that ready to use with rhino6?
Not yet. We are currently working on it.
the release is near?
