Hello guys…
I have a problem with matching data tree and list inputs in the “point in curve” component. as you see in the attached file i have an architectural form and its structure which I need to optimize. in this part of the process I need to find the innermost point of the structure at each predefined section-plane. So my plan is to first find the points inside the form and then find the one which has the most distance to it.
but somehow i cant make the “point in curve” component to work properly.
I have tried grafting, flattening, simplifying, trim tree, clean tree and lots of other combinations but somehow I can’t figure it out. I believe it should be pretty simple and straight forward but I am stuck on it for 2days now… If you can have a look and help me I would appreciate it a lot.
form structure.gh (343.5 KB)
