I’ve built a plugin with help with AI called FastenWorks and wanted to share it with the community. It generates real, watertight NURBS solids for fasteners and hardware (not meshes) so they render cleanly, boolean reliably, and 3D printing.
In my line of work I need to create product assembly instructions and concepts designs. I created a crude version for my furniture hardware assembles. I thought I would let Claude help me develop it further. It turned into something more than I could have done on my own. Having a hardware generator has been really helpful as I find it annoying to download a mesh of parts or maintain a fastener library. I used BoltGen for years but was needing more types of fasteners than it offered. For my work, it’s more than enough to get the job done. Hope someone can find this useful in their work. This is free plugin, so don’t expect it to be industrial strength. I would consider adding requested parts if you have fasteners you are missing.
What it makes:
• Bolts, screws, nuts, and washers — lots of head and drive styles
• Real internal threads cut into your own solids
• A deep “Other Hardware” set: casters, furniture levelers, grease fittings, dowel & cotter pins, shelf pins, rivets, cam/furniture connectors, anchor shackles, and more
Features:
• Metric and imperial standard sizes, or enter your own dimensions
• Level-of-detail control, from a lightweight schematic to full render detail
• Place hardware straight onto a surface or solid, with optional matching thread or clearance holes cut for you
• Bill-of-Materials (BOM) report for all the hardware in a model
• Repeat-last-part for quick duplicates
• Block Support
Gives you the option of making matching washers and nuts when creating bolts.
Available via food4rhino.com and Package Manager.
It’s far from perfect, but hopefully it will get better with each update. I will do my best to keep it up to date. I would love to hear what you like and don’t like so I can make improvements.
Minimum Requirements: Rhino 8 (Windows & Mac). Python 3 .NET Framework 4.
Tested with Rhino 9 with no issues so far.
