Faro digitizer question
Hi All, had a question on a Faro ScanEdge digitizer. Does Rhino have the ability to be used with this digitizer? There is some software that goes with it to run in Solidworks directly.
Was hoping someone has had experience in this area. Thank you
-----Mark
If I remember correctly there was a plugin called quokka that captured scan data (worked with a Microsoft Connect too)
Not sure if it was compatible with the faro…
