Falling points from the top of a geometry
I’m somewhat new to grasshopper and I always seem to find myself in what seems like a simple problem but overly complicated solutions when it comes to grasshopper.
I am trying to emulate the way a point (as a droplet of water or a rolling ball) would fall from the top of a geometry. I have seen this done with surfaces and have poked around in their scripts, but havent been able to figure out how to translate it into what would almost look like a simulation for water on a building. If anyone can help that would be great. Thank you!!
These are the geometries i’m trying to use. If you need a file i can attach but any example with a geometry will give me a better understanding.
@Daniella_Pia
Maybe this will do for you?
Rain.gh (339.3 KB)
this is great. Thanks so much!
Is there a way to follow these points to create a path? similar to wind and water simulations? to get a curve from the point movements?
Let me figure that out once I am around a computer today. That sounds pretty sweet. I will give it a shot. Suspicion that you could try, would data recorder plugged into spline curve and swapping out the Bouncy solver for the step solver do the trick? :thinking: Granted, the video that I showed had 10,000 points. If you go recording those points at each step…
Hah! Yeah i had to bring my point number down a lot when i was messing with it but I’ll see if I can do what you said.
All I could seem to get were point connections for the point before and after- which created straight lines at various angles, or just a jumbled mess of curves on the “floor” where they fall.
Rain2Thoughts.gh (354.5 KB)
Rough Rough curves with Rough concentration points.
Rain2Thoughts.gh (32.5 KB)
this is really cool. Thank you so much for doing this. When i ever get a final result with the scripts you helped with i’ll send it along.
