Why extruding non-planar curve does not result in a solid when solid option is “yes” within Extrude command? How to make solid?
Hello - that has always been the case - there is not a way for Rhino to reliably build a cap surface on an arbitrary non-planar curve.
Pascal, Can you point me to info on how to construct a non-planar solid?
Thanks
Hello - my guess is, with this example, you can Patch the top and bottom edges and Join.
