I need some python code for extracting the azimuth angle of a scene sun light without having to open the sun panel, ideally not even selecting the light but rather using a specific existing object name such as “MySun”.
I’m trying to write a script to match the rotation of a domelight texture to match the current sun azimuth rotation.
I have some bits and pieces already but I can’t figure out how to get the sun angle from its vector data.
My python scripting skills are pretty poor …
Can anyone help ?
Thanks !
if you´re after the real sun instance object of the document, this should do it:
import scriptcontext
def SunAzimuth():
sun = scriptcontext.doc.Lights.Sun
if not sun: return
print "Azimuth:", sun.Azimuth
SunAzimuth()
c.
Thanks clement
Actually I’m not after the document sun but a vray sun which is trated by Rhino as any directional light, so maybe could be identified along the lines of:
#Find VRay sun in document lights = rs.LightObjects() for i in range(0, len(lights), 1): if (rs.LightName(lights[i])=="MySun"): sun = lights[i]
Ok, hang on for a while, i´ll have to try something…
the question is where is north in your case ? below just gets the polar coordinates from the light direction vector xy components. It starts rotation at the x axis and rotates counter-clockwise, so y-axis would be 90 degree:
from math import atan2, degrees
def DoSomething():
ids = rs.ObjectsByName("MySun", select=False, include_lights=True)
if not ids: return
if not rs.IsDirectionalLight(ids[0]): return
direction = rs.VectorReverse(rs.LightDirection(ids[0]))
deg_angle = degrees(atan2(direction[1], direction[0]))
if deg_angle < 0: deg_angle += 360
print deg_angle
DoSomething()
does that help ?
c.
Actually the north is at 12 oclock (zero degrees) and increases clockwise so 3 oclock is 90 degress and 9 oclock would 270. Can you modify it ? Thanks
(BTW how do you quote the code in the message editor so that it displays color coded ?)
got it, simply change the direction indexes to:
atan2(direction[0], direction[1]
Thank works now. Thanks.
just type like this:
```python
then paste the python code and end like this
c.
Cool. Thanks so much for your help !
One more question if i may …
How can I get out of a script that is meant to loop many times though a list:
for i in range(0, len(a_list), 1):
more code
etc
It seems like the only way is press esc many times and hope that it stops. Not very elegant or even effective sometimes.
Thanks
@juancarreras, try this:
def DoSomething():
for i in xrange(100000000):
if scriptcontext.escape_test(False):
break
print "loop stopped at:", i
DoSomething()
c.
Great. That worked !
Thanks again.
