I can get the values for Azimuth and Altitude from scriptcontext.doc.Lights.Sun.Azimuth and scriptcontext.doc.Lights.Sun.Altitude
But those are only the values for the date that is set in the Rhino document.
Is it possible to get values for several dates using a python script?
Thank you!
In the Rhino Document, yes. And it gets picked up by scriptcontext.doc.Lights.Sun
But I don’t know how to input a list of values for multiple dates.
Hmm. Yes, digging in to Rhino.DocObject via Python I get errors if I try to access AnimationSettings. I don’t know if I am doing this correctly
@piac is it possible to set the date via Python?
Thanks, graham
@Dancergraham Actualy you don’t need to change the date for Rhino Document Sun
. You can create a non-document controlled Sun
set the postition of it and then get the Altitude
and Azimuth
import ghpythonlib.components as ghp
import Rhino
date = ghp.ConstructDate(2019,month,day,hour,minute,0)
mySun = Rhino.Render.Sun()
Rhino.Render.Sun.SetPosition(mySun, date, latitude, longitude)
Altitude = mySun.Altitude
Azimuth = mySun.Azimuth
Bogdan_Chipara.gh (21.2 KB)
You can do it if you want to, but it will run much slower.
import Rhino
RhinoSun = Rhino.RhinoDoc.ActiveDoc.Lights.Sun
Rhino.Render.Sun.SetPosition(RhinoSun, date, latitude, longitude)
Altitude = RhinoSun.Altitude
Azimuth = RhinoSun.Azimuth
Graham.gh (18.5 KB)
ok, @Mahdiyar, it works well, thanks. Indeed, better not to change the datetime in rhino document.
I had to test in R6, in 5 it doesn’t work.
