Hi All. I made this sort of manual interface for extracting the closed polygons/polycurves from a set of curves.
Made a bounding surface, split it with the curves and selected/extracted the interior polygons (if not enveloped by original curves it should not be selected).
Is there a cleaner way to generate this interior closed polygons and output them to a cleaner set? A premise is I can´t custom code… (but readily available plugins are ok)
BTW I did search before asking
It works but I have to resort to building the surface and splitting it again and extracting the contours.
Should be a way of producing this result faster/cheaper, right?
