I probably have a small problem for most of you, but I can’t solve it.
I only need the outer curve of the green Voronoi structure marked in red.
Maybe you can help
I would be very grateful to you
kind regards
voronoi boarder.gh (11.7 KB)
Maybe you can help
kind regards
okay, well… I didn’t expect that, my journey was way too complicated.
Thank you
The extrusion and sort list are unnecessary distractions.
You could have used Pop2D and extruded only the cells you cull. Like this:
P.S. Or use Average instead of Sort List:
It’s always fascinating how many possibilities there are
I now want to scale the width of the curve and then connect it to the unscaled curve with a mesh so that I can have a long, smooth transition into the flat area.
I would like to give you the whole definition, maybe you can understand my idea better and can also help me and show possible variants so that I can understand the whole thing better
voronoi boarder.gh (25.7 KB)
You probably want Offset Curve since scale won’t affect “width” of a curve. But you didn’t internalize your curve and I don’t have your plugins… and you didn’t follow any of my advice so maybe you aren’t talking to me anyway?
border…
ohha, I see I uploaded the old file. I’m sorry, it was probably a bit late in the evening yesterday.
“pop2D” definitely makes more sense, but if I use “Average” then I no longer have the option to determine the number of cells along the line.
Thanks, “offset curve” is exactly what I was looking for
My current goal is for the outermost curve of the outermost cells to move further away from the whole so that I have a, I would say more organic transition into the flat.
Unfortunately I can’t get an area created between the 2 curves, traced in the picture with blue lines, which I can then connect with the ones that have already been created
In the end it should be a kind of rivertable that I will mill with my CNC machine.
By the way, the plugins I use here are purely for visual purposes and not relevant to the whole thing
Here is the correct file again
This file has a ‘Crv’ param that is not internalized. I said that yesterday
P.S. I used the internalized curve from voronoi boarder_2024Oct16b.gh (one of the files I posted yesterday) so I can see what you are doing but I’ve lost interest in trying to figure out what you want now. I really don’t care.
yes, you mentioned that yesterday
Please tell me how I should do it correctly,
I right-clicked on the crv components and clicked internalize data at the bottom and selected the corresponding curve in rhino
See the P.S. I added to my previous post.
I’m sorry, I wasn’t aware of the crv component’s internalize.
In any case, thank you very much for your time and your help, I really appreciate it
