Im trying to create a direct link between Rhino geometry and GMSH, an open-source Finite element mesher.
GMSH is using the OpenCascade geometry kernel and here i would like to map the NURBS surfaces directly from Rhino3dm to an OpenCascade representation using PyOCCT and Rhino3dm in python.
I can export .stp file from Rhino and import this into the kernel, but i would rather not use this approach.
Has anyone here done something similar or can you point to some projects for inspiration?
Alright, thanks Dale. I think I have crunched my way through this.
It seems that I loose the layer structure and the user data when going the .stp approach and as far as i can tell there is not functionality for exporting stp from the rhino3dm library
It seems like GMSH is being actively worked on, and it’s written in C++. You might contact the developers and see if they could add .3dm file support using our free openNURBS toolkit, which is also written in C++.
There are also a of OpenCascade file export plug-ins available for Rhino:
