Exporting each closed solid polysurface to a seperate STEP file
Good day all,
I am currently facing a small issue. I have created a design/assembly of multiple Closed solid polysurfaces. All of those closed solid polysurfaces, i want to export to a separate STEP file for each part. Does anybody know if this is possible through a command, or do i have to export each part manually?
Thanks in advance!
Regards,
Siemen
This can be done with a script. I didn’t have a STEP export script in my library, so I quickly hacked one together from some others. You will need to browse to a folder for the exports and then choose in a master file name. The individual object files will have the name “MasterName-1”, “MasterName-2”, etc. It is of course possible to modify the script to use a different file naming convention.
Right now the script is set with the following export options:
_Schema=AP214AutomotiveDesignCC2
_ExportParameterSpaceCurves=_No
_SplitClosedSurfaces=_No
_LetImportingApplicationSetColorForBlackObjects=_Yes
You can simply open the script file in a text editor and change any of those if necessary.
BatchExportStepByObject.py (1.8 KB)
To run the script, save it somewhere, then use _RunPythonScript and browse to the script file. For more permanent script installation via aliases or toolbars, have a look at this wiki page.
https://wiki.mcneel.com/rhino/macroscriptsetup
Hi Helvetosaur,
Didn’t work before with scripts in Rhino, but with the link you shared it was quite easy to use. It worked perfectly, thank you very much! :smiley:
This works well, thanks! I would like to adopt it into my GH file so i automate and the selection process and name items more specifically. Do you have experience with this, or someone else maybe?
Unfortunatey, I really don’t know how to do this in Grasshopper (yet) - I think GH in V8 does offer plenty of possibilities to do this though.
True, can’t really use that for commercial purposes though. But i found the Lunchbox plugin does this really well. Thanks.
