Export text data from TextDot to csv format
Hi All,
Does anyone know how to export the text data of multiple textdots in one csv file?
Thanks in advance
Roughly:
Get the text dots
In a list, collect the dot texts via rs.TextDotText()
Write the .csv file line by line using standard python file writing code -
or,
Collect the list of texts into one big string with line breaks and write the whole string at once
Do you need a full example?
Something like:
def ExportDotsCSV():
    dots=rs.GetObjects("Select text dots to export",8192,preselect=True)
    if not dots: return
    filter = "CSV File (*.csv)|*.csv||"
    filename = rs.SaveFileName("Save data file as", filter)
    if not filename: return
    file = open(filename, "w")
    for i,dot in enumerate(dots):
        txt=rs.TextDotText(dot)
        #don't add separator for last line
        if i<len(dots)-1: txt+=","
        file.write(txt)
    file.close()
ExportDotsCSV()
This makes one big line with all the texts separated by commas.
For Euro CSV, change txt+="," to txt+=";"
For each item on a separate line change txt+="," to txt+="\n"
To create one big string and write the whole file at once:
    if not dots: return
    to_write=""
        to_write+=rs.TextDotText(dot)
        if i<len(dots)-1: to_write+=","
    with open(filename, "w") as file: file.write(to_write)
ExportDotsCSV()
Thanks Mitch!
It’s exactly what I was looking for!!
