Hi!
I want to check the document for TextDotText when creating a new dot for similar texts, so I never have the same dots twice.
def AddReview():
nr = rs.StringBox (“Enter review number”, None, “Review number” )
note = rs.StringBox (“Enter review note”, None, “Review note” )
point = rs.GetPoint (“Select review location”)
allobj = rs.SelectObjects(
obj = rs.AddTextDot (nr, point)
if nr: rs.SetUserText(obj, “Nr”, nr)
if note: rs.SetUserText(obj, “Note”, note)
AddReview()
any ideas?
Regards,
Thomas
Add a cycle within a cycle checking every textdottext against every other one, but itself.
Hmm okay, i’m new at scripting. Can you give me a start?
I could if it was Rhino script. I don’t know Python too well. Mitch (Helvetosaur) might chime in to help ya.
I guess the simplest would be just to check all the dots in the document every time and see if a dot with the text already exists, if so, ask the user to choose a different text…
def GetAllDotTexts():
dot_texts=set()
dots=rs.ObjectsByType(8192)
if dots:
dot_texts=set()
for dot in dots: dot_texts.add(rs.TextDotText(dot))
#dot_texts is now the set of all dot texts in document
#if no dots, returns an empty set
return dot_texts
def DontDuplicateTextDots():
text_dot_set=GetAllDotTexts()
#run a loop
while True:
user_string=rs.GetString("Dot text?")
if user_string is None or user_string=="": return
if not user_string in text_dot_set:
#no dot with this text in document, OK to add
break
else:
#dot with this text already exists
response=rs.MessageBox("Text dot already exists!",1)
if response !=1: return
pt=rs.GetPoint("Text dot insertion point?")
if pt: rs.AddTextDot(user_string,pt)
–Mitch
Thanks Mitch!
This is the result:
> import rhinoscriptsyntax as rs
> import time
> import getpass
> dot_texts=set()
> if dots:
> dot_texts=set()
> return dot_texts
> #run a loop
> while True:
> no = rs.StringBox ("Enter review number", None, "Review number" )
> if no is None or no=="": return
> if not no in text_dot_set:
> break
> else:
> response=rs.MessageBox("Review number already exists!",1)
> note = rs.StringBox ("Enter review note", None, "Review note" )
> action = rs.StringBox("Action for", None, "Action")
> datemod = time.strftime("%d/%m/%Y")
> user = getpass.getuser()
> point = rs.GetPoint ("Select review location")
> obj = rs.AddTextDot (no, point)
> if no: rs.SetUserText(obj, "No", no)
> if note: rs.SetUserText(obj, "Note", note)
> if action: rs.SetUserText(obj, "Action", action)
> if user: rs.SetUserText(obj, "Modified by", user)
> if datemod: rs.SetUserText(obj, "Date modified", datemod)
> rs.SetUserText(obj, "Resolved (y/n)", "n")
> rs.SetUserText(obj, "Info", " ")
