Export Rhino object with Usertext to IFC
After editing an object in Rhinoceros and exporting it to an ifc file, when I import it again, the user text has “Properties” at the beginning.I am using geometry gym to export to ifc file.
I would like to leave this as the original group.
How can I do this?
ordinary user texts (and expected)
xxx|yyy
after imported
Properties|xxx|yyy
Thank you
You can remove the property set name from the prefix of user text key in recent builds of the plugin by
unticking the option highlighted in this image.
Let me know if I’ve misunderstood and this doesn’t achieve what you are looking for…
Cheers,
Jon
It is useful to exclude prefixes in the output if possible, since they may be read by other systems.
But I think this method is also good.I will consider updating the version.
Thank you very much!
