Cheers all,
I am quite noob into scripts and i have discovered this export objetcs by layer script…
But when i modify it as the tutorial said and i dont really know what i am doing wrong. I copy the script modified i am trying to introduce…
Option Explicit
Sub ExportLayerObjectsIGES
’ Declare local variables
Dim strPath, strFile
Dim arrLayers, strLayer
Dim arrSelected
’ Get the path to and name of the current document.
’ Surround with double-quotes in case path includes spaces.
strPath = Chr(34) & Rhino.DocumentPath & Rhino.DocumentName & Chr(34)
’ Get names of all layers
arrLayers = Rhino.LayerNames
’ Disable redrawing
Rhino.EnableRedraw False
’ Process each layer
For Each strLayer In arrLayers
' Unselect all Rhino.Command "_-SelNone", 0
' Select all objects on layer. Surround layer name ' with double-quotes in case it includes spaces. Rhino.Command "_-SelLayer " & Chr(34) & strLayer & Chr(34), 0
' Make sure some objects were selected arrSelected = Rhino.SelectedObjects If IsArray(arrSelected) Then
' Generate a modified path string ' that includes the layer name strFile = strPath strFile = Replace(strFile, ” .3dm“, ” _ & strLayer & . * obj“)
' Export the selected objects Rhino.Command "_-Export " & strFile, 0
End IfNext
’ Unselect all
Rhino.Command “_-SelNone”, 0
’ Enable redrawing
Rhino.EnableRedraw True
End Sub
