I exported 80 blocks in 5 parent layers as one block definition. The main file is confidential.
When the file is inserted in a new Rhino document, Rhino creates a layer ‘Grasshopper’ for the block definition. I guess this happens because a definition isn’t really attached to a layer?
Can this be avoided and maybe even be fixed? I don’t like seing that ‘Grasshopper’ layer. I’m meticulous with my layer hierarchy and usually when I see the ‘Grasshopper’ layer it means I didn’t specify the layers correctly and there’s a mistake somewhere.
I created a test file with 10 simple blocks but the problem does not happen when inserting the test file.
export_block_definition_layer_problem.3dm (320.5 KB)
export_block_definition_layer_problem.gh (7.9 KB)
test.3dm (232.4 KB)
