Export image from grasshopper
I have multiple cads file need to save images as JPEG . Need all these in a image format in a sequence. Now I just used the print command to set the resolution parameter to 500 X 500 in rectangle print area , the position of print area is from (0,0,0) to (40,40,0). Are there have any easy way to go? Thanks !
Human plugin has a “Save Viewport To File” components, which is useful.
Thank you Gankeyu! I will try it!
I try to use Human plugin, It’s a good but It can not set a very regular size of images. Thank for your help Keyu!
