Export Generated model into JSON
Hi guys,
Is there a way export grasshopper model as a Json file to be able to reconstruct it in three.js ?
The idea is somehow hooked up a server with grasshopper to send JSON files to local web app which uses three.js to build a model back again.
Thank you,
Roman
Check out TT Toolbox and its spectacles plugin
Cheers. I will check them out. Spectacles looks like what I need
The Spectacles plugin is not available on Food4Rhino. Is there a way to export mesh geometry for compatibility with Design Explorer?
