Hi, I want to know how I Explode Polygon to use line and point separately in Python,
I think at first I need to change polygon ToNurbsCurve()
But I cant.
Reza
Hello sailor!
Have you tried explode, shatter or discontinuity components?
Best regards,
Sir Ernest Shackleton
sorry, I want to do this process in Python.
If you are trying to manipulate something in Rhino, you can use either of the following:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Curve_DuplicateSegments.htm
https://developer.rhino3d.com/api/RhinoScriptSyntax/#curve-ExplodeCurves
Else you can use ghpythonlib.components.Explode(), iirc can’t remember the exact library.
Thank You for responding, but for exploding in this way I need to change polygon to curve, such as picture. I cant change Polygon to curve.
The error in the line 11 RotateObject
As @AndersDeleuran once pointed out to me, if you have a polyline, you should just use GetSegments.
This way you don’t need to convert and also the result will be the lines, not “Line-Like Curves”.
Thank u All Dears, it worked
