Why?
Why?
The Point expected is either a System.Drawing.Point or a Rhino.Geometry.Point2d. You can see the two overloads here
MouseCursor.Location gives you already a Point2d, so use that directly.
Categorized.
Please assign your new messages to the appropriate category.
Thanks
Thanks @nathanletwory
MouseCursor.Location gives Point2d, but ScreenToClient expects Point. How do I convert it?
I’m actually want to draw a brush stock that is thicker when mouse move slowly, and thinner when mouse move fast.
So I end up working it out… after heaps of trial and error
This puts a point at my mouse cursor position!
but, when i put a timer on it, Rhino viewport locks up after about 5 seconds
As I mentioned before, the overload should automatically take the Point2d. This works just fine:
import Rhino
pos = Rhino.UI.MouseCursor.Location
res = Rhino.RhinoDoc.ActiveDoc.Views.ActiveView.ScreenToClient(pos)
print res
To dynamically draw while moving mouse you may want to use the dynamic draw approach. Here is an example:
Here the guide to the C++ version that explains a bit more Dynamically Drawing Geometry when Picking Points with C/C++
