Example file support member size seems to be maxed out
Howdy,
I am loading up This and every tutorial file for karamba and I noticed that the supports are maxed out for size no matter where it is. Colors do appear to correspond to stress but size does not. I am running student pro license in case that has an effect.
Thanks,
abiquiuguy
05_ProjectedVoronoiPatternGridshell.gh (59.1 KB)
Hi, when I open your definition I see the correct profiles: image
Do you have the correct units defined in your Karamba setup? It is set up for meters
Thank you so much. That is exactly what was up.
