First year architecture student here. Installed Rhino v7 on dell workstation with 64 gb of ram, ssd and gtx1060. I7 xeon cpu. Pretty powerful windows 10 machine.
I am running into issues trying to Make 2d with vertical Clipping plane. Horizontal clipping pane works, but horizontal doesn’t. The model is pretty complex (for a first year student).
I tried other computers (3 windows and 1nac) without success.
What is interesting that I shared the model with another student and they were able to perform horizontal clipping pane on my model using pretty weak Lenovo laptop.
I am using 90 days eval version. Could that be the reason why horizontal clipping is failing?
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 72Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1060 6GB (NVidia) Memory: 6GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\misha\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.0\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.1.0.0
C:\Users\misha\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
Hi Oxana -
There isn’t anything in that SystemInfo that looks wrong. I would probably update to the current 7.5 version, though.
How do you define “doesn’t work”?
Is the view clipped when the viewport is in Wireframe mode?
Does it work as expected when using a simple box in a new file from a factory-default template?
If it is scene-specific, can you post the file here? Or upload to Rhino - Upload to Support</ (make sure to copy the URL to this thread in the comments field if you do)?
Hello - the clipping plane in your file seems to work here - note that clipping is applied per view, so make sure, in the clipping plane Properties, that it is set to clip the view you are interested in - as your file opens, the Right view is clipped.
That’s not exactly what I am looking for. The ClippingPlane also works for me, in sense where I see it clipping, however, when I try to Use Make2D of the vertical ClippingPlane in the “Right” view, Make2D is stuck for several hours without any progress. My problem wasn’t with the ClippingPlane not showing up but that wehn
OK, yep, I got it… @oxana - Make2D in Right works here, however there is a linked block missing - just in case that is the bad guy, can you post or send me that?
“A linked block definition cannot find a file named
… s/Buliding 7 Details.3dm”
“That’s not exactly what I am looking for. The ClippingPlane also works for me, in the sense where I see it clipping, however, when I try to Use Make2D of the vertical ClippingPlane in the “Right” view, Make2D is stuck for several hours without any progress. My problem wasn’t with the ClippingPlane not showing up but that when I try to use Make2d with the ClippingPlane in the vertical position, it doesn’t make any progress. For some reason what I am trying to achieve works on some weaker computer systems and not on mine. Could you try testing out making Make2d from the “Right” view with the clipping plane that is already set up. Thank you for your help.”
