Hi everyone
I have boxes on different heights. So my goal is to pick always the highest box in relation to the top surface. I evaluate the Z values of the boxes, but then i stucked to filter the boxes in relation to this Z value.
Any advise?
Hi everyone
Any advise?
Sort List by Z value.
I did deconstruct point. then sorted the Z values. now i want to select all the boxes with the highest Z values (14).
In my example i would have 2 boxes with Z values 14. they are in different branches.
boxes.gh (15.1 KB)
You could have posted your GH model with your opening question… And you could start by having only one box at the highest point instead of two…
Returning two boxes that happen to be at the same elevation is an extra complexity for a beginner. Learn how to walk before you run.
Thank you very much. Next time with the script first…
That was the goal and @HS_Kim Thanks for the solution…
