How can I get Euler angles from a transformation matrix?
.GetYawPitchRoll returns a boolean, you need to use “out” to get your values.
private void RunScript(Transform Matrice, ref object Yaw, ref object Pitch, ref object Roll)
double yaw, pitch, roll;
bool success = Matrice.GetYawPitchRoll(out yaw, out pitch, out roll);
Yaw = yaw;
Pitch = pitch;
Roll = roll;
…typo?
Lo stesso degli altri che non ho specificato.
Var?
Hello
If you want an answer it is surely best to post the script.
Because at first glance I shall say you have done an error. Euler angles are tricky.
Hello Peter
I am doing 6 dof simulations. Yes angles are tricky because if you use matrix quaternions … order of rotations are not always the same. Sometime
Yaw * Pitch * Roll
And sometime
Roll * Pitch * Yaw.
So an error in the order brings error at the end …
Well … the core of the matter is to define what exactly are YPR in the classic 3D 4*4 TMatrix (see capture above as well for the orthodox (or not) way to cut the mustard).
Anyway, get this as well
JN_TransMatricesMaths.pdf (3.0 MB)
May The Force (the Dark option) be with you.
But there is no solution or answer that does not require study ceiling?
The methods indicated by @dale… how can it help me?
At the moment I can not deepen the theory. Is there a quick fix?
Post your script
Post your script
Post your script
it is quite impossible to help you just with a screen copy.
Thanks @dale, unfortunately, however, the code is not able to get the initial angles.
If I can get the Euler angles, applying opposite angles I return to the initial configuration.
Eulero_Forum.gh (128.5 KB)
Did you notice that the values are mirrored in the inner 3x3 matrix. I bet it’s because of reversing in wrong order or assigning the values to wrong indices. Still, as Laurent says, Euler angles are tricky. I found this website very useful when I had to implement my own math library for it. Maths - Conversion Euler To Matrix - Martin Baker
And so Transform.GetYawPitchRoll doesn’t work?
Hello
I looked a bit at your script. You use Pufferfish. So there is surely a difference between angle from Pufferfish and rhinocommon. In aeronautics for rocket x is oriented tothe front z at the bottom
ROLL is on X. …
