Sérgio1
(Sérgio)
April 23, 2025, 11:26am
1
I’m trying to get angles from a plane using either GetEulerZYZ, GetYawPitchRoll and GetQuaternion.
This is to set work planes to a robot (I’m using robotdk) and at this point I don’t know which method will work for me.
I’m stuck using any of those methods because I can’t extract any information from it.
Dim vTCPInfo = Transform.ChangeBasis(Plane.WorldXY, vTCPPlane)
'vTCPPlane = {Origin=-185.778389695857,76.745590069475,46.8938003683418 XAxis=0.441596373625533,0.896311660205494,0.0402249994462356, YAxis=-0.00177615020492446,0.0457064664330206,-0.998953334353841, ZAxis=-0.897212064169463,0.441062724230781,0.0217757939670092}
'vTCPInfo = {R0=(0.441596373625533,0.896311660205494,0.0402249994462356,11.3647928452118), R1=(-0.00177615020492446,0.0457064664330206,-0.998953334353841,43.0069781771568), R2=(-0.897212064169463,0.441062724230781,0.0217757939670092,-201.553381260991), R3=(0,0,0,1)}
Then any method fails:
vBolRes= vTCPInfo.GetEulerZYZ(alpha, beta, gamma)
vBolRes= vTCPInfo.GetYawPitchRoll(yaw, pitch, roll)
vBolRes= vTCPInfo.GetQuaternion(quaternion)
Also tried with Transform.PlaneToPlane with the same results.
is this the correct way to use those functions, I’m missing something here?
Thanks in advance
dale
(Dale Fugier)
April 23, 2025, 9:42pm
2
Hi @Sérgio1 ,
Here is a test you can run in Rhino 8:
#! python 3
import Rhino
def Test():
wp = Rhino.Geometry.Plane.WorldXY
xaxis = Rhino.Geometry.Vector3d(0.441596373625533,0.896311660205494,0.0402249994462356)
yaxis = Rhino.Geometry.Vector3d(-0.00177615020492446,0.0457064664330206,-0.998953334353841)
zaxis = Rhino.Geometry.Vector3d(-0.897212064169463,0.441062724230781,0.0217757939670092)
xaxis.Unitize()
yaxis.Unitize()
zaxis.Unitize()
xform = Rhino.Geometry.Transform.Rotation(wp.XAxis, wp.YAxis, wp.ZAxis, xaxis, yaxis, zaxis)
rc, a, b, c = xform.GetEulerZYZ()
if rc:
print("alpha: {}, beta: {}, gamma: {}".format(a, b, c))
rc, a, b, c = xform.GetYawPitchRoll()
if rc:
print("yaw: {}, pitch: {}, roll: {}".format(a, b, c))
rc, a = xform.GetQuaternion()
if rc:
print("quaternion: {}, ".format(a))
if __name__ == "__main__":
Test()
Note:
Transform.ChangeBasis creates a change-of-basis transformation, which is not the same as the rotation transformation.
Transform.PlaneToPlane only creates a rotation transformation if the origins of the input planes are the world origin.
Hope this helps.
– Dale
dale
(Dale Fugier)
April 23, 2025, 10:13pm
3
Another example, this time with C#:
// #! csharp
using System;
using Rhino;
using Rhino.Geometry;
Plane wp = Plane.WorldXY;
Point3d origin = new Point3d(-185.778389695857,76.745590069475,46.8938003683418);
Vector3d xaxis = new Vector3d(0.441596373625533,0.896311660205494,0.0402249994462356);
Vector3d yaxis = new Vector3d(-0.00177615020492446,0.0457064664330206,-0.998953334353841);
Vector3d zaxis = new Vector3d(-0.897212064169463,0.441062724230781,0.0217757939670092);
xaxis.Unitize();
yaxis.Unitize();
zaxis.Unitize();
Plane tp = Rhino.Geometry.Plane.CreateFromFrame(origin, xaxis, yaxis);
Transform xform = Rhino.Geometry.Transform.PlaneToPlane(wp, tp);
if (xform.IsAffine)
bool rc = xform.DecomposeAffine(out Rhino.Geometry.Transform linear, out Rhino.Geometry.Vector3d translation);
if (rc)
Console.WriteLine("translation: {0}", translation);
double a, b, c;
rc = linear.GetEulerZYZ(out a, out b, out c);
if (rc)
Console.WriteLine("alpha: {0}, beta: {1}, gamma: {2}", a, b, c);
rc = linear.GetYawPitchRoll(out a, out b, out c);
if (rc)
Console.WriteLine("yaw: {0}, pitch: {1}, roll: {2}", a, b, c);
rc = linear.GetQuaternion(out Quaternion q);
if (rc)
Console.WriteLine("quaternion: {0}", q);
– Dale
