Hi @curtisw,
recently i’ve reported here that i cannot import from some dll files to use methods from System.Windows.Media and System.Windows namespaces required to style Eto controls in Rhino 8.
I’ve then found your post here which mentions the command SetDotNetRuntime which seems to fix the issue once set to NetFramework. But it requires a restart of Rhino 8 and probably changes other defaults. So i would like to find a solution for my problem which works ‘out of the box’, preferrably crossplatform.
I am coding an image viewer in Eto which is capable to display high res images with transparent background:
the problem is, the checkerboard. It is applied to an Eto.Forms.Scrollable like this:
self.scrollable.ControlObject.Background = self.CreateTileDrawingBrush()
the brush used is created with this function:
def CreateTileDrawingBrush(self):
drawing_brush = Media.DrawingBrush()
drawing_brush.TileMode = Media.TileMode.Tile
drawing_brush.Stretch = Media.Stretch.None
drawing_brush.AlignmentX = Media.AlignmentX.Left
drawing_brush.AlignmentY = Media.AlignmentY.Top
drawing_brush.Viewport = Rect(0,0,16,16)
drawing_brush.ViewportUnits = Media.BrushMappingMode.Absolute
drawing_1 = Media.GeometryDrawing()
drawing_1.Brush = Media.Brushes.LightGray
group_1 = Media.GeometryGroup()
rect_top_left = Media.RectangleGeometry(Rect(0,0,8,8))
rect_bottom_right = Media.RectangleGeometry(Rect(8,8,16,16))
group_1.Children.Add(rect_top_left)
group_1.Children.Add(rect_bottom_right)
drawing_1.Geometry = group_1
drawing_2 = Media.GeometryDrawing()
drawing_2.Brush = Media.Brushes.White
group_2 = Media.GeometryGroup()
rect_top_right = Media.RectangleGeometry(Rect(8,0,16,8))
rect_bottom_left = Media.RectangleGeometry(Rect(0,8,8,16))
group_2.Children.Add(rect_top_right)
group_2.Children.Add(rect_bottom_left)
drawing_2.Geometry = group_2
drawing_group = Media.DrawingGroup()
drawing_group.Children.Add(drawing_1)
drawing_group.Children.Add(drawing_2)
drawing_brush.Drawing = drawing_group
return drawing_brush
I wonder if Eto could provide a build in way to display such a checkerboard behind controls to indicate transparency ? For the ColorPicker control this would be useful if the color has transparency. Eg. below shows two ColorPicker controls, the upper one uses plain red (255,0,0) and the lower one is also plain red but with 50% transparency.
It would be great if the control shows a checkerboard background to indicate the transparency.
Same goes for an ImageView in case the ImageView.Image contains transparent pixels. Could this be added to Eto, maybe as a property of the control or just as i’ve shown it using some kind of build in DrawingBrush i could assign on my own ?
thanks,
c.
