Hi I’m trying to use the Eto.Forms.OpenFileDialog and its Filter property with Rhino Common to achieve the following behaviour:
the user can select a SINGLE file type filter (PNG, BMP, JPG, ZIP) if he already knows precisely what he’s looking for – or –
the user can select an “ALL FILE” filter to browse all files
For the single file type filters all is working as expected:
dialog.Filters.Add(new FileFilter("Png files", ".png"));
dialog.Filters.Add(new FileFilter("Jpg files", ".jpg", ".jpeg"));
but if I try to add a filter like this
dialog.Filters.Add(new FileFilter("All files", ".*"));
the dialog is shown correctly, however as soon as I select the “All files” filter from the combo box, Rhino crashes.
I guess filters in a “regexp style” with wildcard characters are not managed behind the hood of Eto.Forms.OpenFileDialog class.
I also tried to use Rhino.UI.OpenFileDialog instead, where the Filter property can be set up in the classic way `Png files (*.png)|*.png|All files (*.*)|*.*`, but no filter is shown.
I’m running my plugin on Rhino 8 for macOS.
Rhino version: 8.24
macOS version: Tahoe 26.0.1
Is there any workaround to achieve the mentioned behaviour?
Thanks
dale
(Dale Fugier)
October 20, 2025, 3:35pm
2
Hi @p.stragliotto ,
#! python3
import Eto
import Rhino
import System
def Test():
dialog = Eto.Forms.OpenFileDialog()
dialog.Title = "Open"
dialog.Filters.Add(Eto.Forms.FileFilter("BMP", [".bmp"]))
dialog.Filters.Add(Eto.Forms.FileFilter("JPG", [".jpeg"]))
dialog.Filters.Add(Eto.Forms.FileFilter("PNG", [".png"]))
dialog.Filters.Add(Eto.Forms.FileFilter("Supported Files", [".bmp", ".jpeg", ".png"]))
dialog.Filters.Add(Eto.Forms.FileFilter("All Files", ["*"]))
result = dialog.ShowDialog(Rhino.UI.RhinoEtoApp.MainWindow)
if result == Eto.Forms.DialogResult.Ok:
path = dialog.FileName
print(dialog.FileName)
if __name__ == '__main__':
Test()
– Dale
Thanks @dale
I tried your code as-is on the Script editor, and actually Rhino for macOS crashes the same when selecting “All files” from the combo box.
It works for Rhino Windows, I need to make it work on macOS as well though.
I think this is a bug that needs a fix, in the meantime I will apply no filter and just show all files by default to the user.
Cheers
dale
(Dale Fugier)
October 21, 2025, 3:30pm
4
Hey @p.stragliotto - I tested my script on the Mac, successfully. Let me look into this a little more.
– Dale
curtisw
(Curtis Wensley)
October 21, 2025, 4:06pm
5
Hey @p.stragliotto ,
Looks like we have already done a fix for this in Rhino WIP, and should be back ported to Rhino 8.
I’ve filed RH-90064 Eto FileDialog crashes when specifying all files to get that fixed up.
Thanks for reporting the issue!
brian
(Brian Gillespie)
October 21, 2025, 9:29pm
6
