Rebekah1
(Rebekah)
June 12, 2023, 6:13pm
1
I’ve taken a look at Eto Forms, Rhino.UI, as well as System.Windows.
Which one of these would work best for creating a button that creates an Open File dialog that will allow users to view and alter DWG files in Rhino through a plugin? I’m using C#, and specifically not Python.
At what point do I use Eto Forms, and at what point do I use Rhino.UI?
Any examples would be helpful as well.
dale
(Dale Fugier)
June 12, 2023, 9:59pm
2
Hi @Rebekah1 ,
Unless you want to prompt for .3dm files, I’d just use Eto.
string filename = null;
if (mode == RunMode.Interactive)
var ofd = new Eto.Forms.OpenFileDialog
MultiSelect = false,
Title = "Open",
Filters =
new Eto.Forms.FileFilter
Name = "AutoCAD Drawing (*.dwg)",
Extensions = new[] { "*.dwg" }
Name = "AutoCAD Drawing Exchange (*.dxf)",
Extensions = new[] { "*.dxf" }
CurrentFilterIndex = 0
var result = ofd.ShowDialog(RhinoEtoApp.MainWindow);
if (result != Eto.Forms.DialogResult.Ok)
return Result.Cancel;
filename = ofd.FileName;
else
var gs = new GetString();
gs.SetCommandPrompt("Name of AutoCAD file to open");
gs.Get();
if (gs.CommandResult() != Result.Success)
return gs.CommandResult();
filename = gs.StringResult();
filename = filename.Trim();
if (string.IsNullOrEmpty(filename))
return Result.Nothing;
if (!System.IO.File.Exists(filename))
RhinoApp.WriteLine("File not found.");
return Result.Failure;
// TODO...
return Result.Success;
– Dale
