I am still running into issues when using a DropDown inside a GridView. Selecting a value from the DropDown seems to work as long as the click occurs in the active area of the GridView. Once the DropDown exceeds the bounds of the row area a mouse click will not change the selected item but rather acts like a row selection. Really weird.
Have a look at the upper gif animation. Lower row
first trying to select the value via mouse click → no change
second using the arrow keys and enter → change occurs
If the DropDown is in the bounds of the row area (active area of the GridView) the mouse click does work.
@curtisw Do you have any idea how to change this behaviour?
attached you can find a sample project that I just setup. I hope you can see the behaviour. Just run and you should get a panel with two columns and some values. The dropdown is not bound back to the data right now, but the clicking behaviour is obvious to see. Hopefully its an error on my end ;-).
That is the exact issue I am facing, with the ComboBoxCell in gridview, when those dropdowns have items outside of that border, then the selection works. My best guess is that by clicking on the combobox items that fall in the same area as the gridview, Eto is interperting that as clicking on the gridview instead, thus focusing on the gridview instead of selecting the item in the combo box.
