I use polycam for making scans. Sometimes only when I use the crop or rotate tool in polycam then export my model as an OBJ, it wont open in rhino. I always get this message in the command line “Errors occurred reading this file, may be incomplete.” Im not sure if the problem is on polycams end since this only happens if i crop or rotate the model, or if its rhino. I have no trouble opening the OBJ in blender or maya.
AFT Stern.zip (15.5 MB)
hi @Tommy804 I can confirm it doesn’t open in Rhino 7 and older
The file does open correctly here in Rhino 8.
Opening the file in Rhino 8 shows a non-manifold edge. Maybe what causes problems in Rhino 7?
If you need to stay in Rhino 7 Nautilus plugin that imports OBJ is working with this file.
Nautilus exports one invalid mesh that can be healed,
Welded, and disjoined it seems to output a quite good mesh without many naked edges
I used a library that was given here
I use this one
The others tools are surely relying on Rhino tools so they fail like Rhino
TTToolbox outputs 2 valid mesh (just in Rhino 8)
Pancake exports 2 valid meshes (just in Rh8)
read aft stern.gh (12.4 KB)
